KA2 Flash erase
KA2 Flash erase
arthurhco
I am programming an RS08KA2 with CW/OSBDM using the E-Value-8 board, but had some issues and no longer can reprogram it. The Flash menu does not show up in the debugger window and Flash Erase command generates "Error: no such command".
How to do a mass erase with the mentioned setup or any workaround ?
Arthur.
Tags (2)
