about S32K148_lwip phy
15736231627
Hello, I found that the phy used in the Lwip_S32K148 routine of SDK is TJA1011, but I want to use another PHY such as KSZ8041,. Which parts of the program should I modify to communicate, such as ping??
veronicavelciu
Could you provide more details about the Lwip_S32K148 routine you are referring to? The lwip stack should be independent of the transceiver.
Veronica
