I need some sort of document that shows me where the connector headers and mounting holes are on the NXP S32K148EVB board. Can anyone help with this? I'm trying to design an enclosure that holds this board along with other components so physical positioning of components is important.
Hi Liam Burns,
Please download the "S32K148EVB Evaluation Board – Quick Start Package (REV 2.2 ) "
Then you will find these files.
Hope it helps.
Robin
Hey Robin,
Thanks for the info but that package doesn't have any information I can use. The layout files are probably what I need but I'm not able to open them in eagle.
Liam
Hi Liam,
Sorry for the delay!
This file is generated by Allegro. So that you can not open it by using eagle.
Maybe you can use Allegro Free Physical Viewer.
Robin
