Using HCI as an example, whether the program has a reserved position to adjust the frequency offset(xtal Trim)?
Dear Mario
Received, thank you for your support
Hi Daniel,
The example es doing the trim, please look at the board.c file BOARD_tcxo32M_compensation_run. In this case, the example is not sending a temperature threshold and a delay.
Also, the function is calling the CLOCK_Xtal32M_Trim(XO_32M_OSC_CAP_Delta_x1000, &BOARD_Clock32MCapacitanceCharacteristics);
Mario
