MK12 Using FlexRAM
MK12 Using FlexRAM
mylim
Hi, I would like to find out how to use the FlexRAM to as storage of device information eg. Device Address & configuration parameters.
I am using MK12DX128VLH5 which has 64KB FlexNVM & 4KB FlexRAM.
I have referred to MCUXpresso SDK API Reference Manual and \twrk21d50m\driver_examples\flash.
I have only have 10 bytes of data to be saved.
Can I check if the pflash example is the right reference to use?
Thanks.
kerryzhou
Hi mylim,
  Share one Kinetis K20 50Mhz  eeprom register level source code for you.
   You can check it, just check the related register is the same as your K12 or not, then you can use that code do EEPROM partition and the data writing.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
mylim
Hi kerryzhou‌,
I have a question, is there any difference between
int partition_flash(int eeprom_size, int dflash_size)
and splitting the flash in the properties?
Thanks.
kerryzhou
Hi mylim,
   Split function is just divide the original defined flash range to a lot of other range and length:
Split is not the partition, you can consider it as the linker file flash definition.
but EEPROM partition means use the flexNVM as the EEPROM backup area, use the FlexRAM as the EEPROM emulated address.
More details, please check the kinetis reference manual flash chapter, find the eeprom partition, you will be more clear about it.
Wish it helps you!
Kerry
