I'm new to devloping with a usb host and i need resources to better understand how your API works.
I'm planing that my product will have a usb hub that a usb flash drive for dataloging(in a fat file system(.db/.csv/.bak)) and a vcp (ft232) will be connected to. i've tried your host example code but they don't give much info on how they operate and MCUXpresso SDK API Reference Manual: Introduction don't talk about the host api nor the fatfs.
I'm running my app on a rt1011.
Can you please help?
Hi ,
The attachment contains some documents for the USB stack, please refer to them for details.
TIC
Also how dose the fat file system api works?
Thanks for your reply.
To provide the fastest possible support, I'd highly recommend you refer to the usb_host_msd_fatfs demo in the SDK library.
TIC
thanks but it seem than the pdfs that you attached are modifiable and non fixed.
