MIMXRT685-EVK Debug Fail
ray_deng1
Dears,
  I got stuck at MIMXRT685-EVK Debug, while I following the Getting Start with XPlorer for RT600.pdf, J-Link runs normal, and XPlorer cannot process.
When configured debug and connecting, it appears as below,
I Clicked OK, it report below error,
Clicked OK, then,
Can you please kindly help to advice?
Thanks & BRs,
Ray
Tags (2)
kerryzhou
Hi Ray Deng
  When you build the DSP project, do you meet any build issues?
This is my situation:
Tomorrow, I do more test about it.
Kerry
ray_deng1
Hi Kerry,
   Yes, it is the error reported from Makefile,
BRs,
Ray
kerryzhou
Hi Ray Deng,
  I just ignore the errors, and debug the code, I can enter the debug mode:
But, before I download the DSP code, I have downloaded the ARM core code, and run it, then debug the DSP code.
This is the printf information:
The xt-ocd.exe -c topology.xml information is also the same as you!
Do you download the ARM core at first with the MCUXPresso IDE?
Kerry
kerryzhou
Hi Ray Deng ,
  Please tell me which XPlorer IDE version you are using now? Xplore IDE 8.0.10?
  Do you also refer to  chapter 1.5 Install Xtensa On Chip Debugger Daemon, please make sure you really do it step by step following the document.
Kerry
ray_deng1
Hi Kerry,
   Thanks for your kindly help,
   I DO following the steps that Getting Started with Xplorer for RT600.pdf. My Xplorer version is 8.0.10.
BRs,
Ray
kerryzhou
Hi Ray Deng
  Thanks for your information.
  I will do it on my side, please give me more time.
  Any updated information, I will let you know ASAP, please keep patient, thanks.
Kerry
