Firmware Upload using LPC LINK-2 possible?
hemanthvasista
Hello ,
Is it possible to get firmware (xxx.axf) of the connected target (upload)?
I am having LPC LINK-2 in MCUXPRESSO IDE.
regards,
Hemanth
jingpan
Hi Hemanth,
Do you want to read back firmware from target chip? You can only read back binary firmware. It's impossible to read  back .axf file. https://www.programmersought.com/article/3980249048/
MCUXpresso can't read data back. You can download jlink application to LPC LINK2 and use Segger software to read.
Jing
andybeeson
As you are already using MCUXpresso IDE, you could alternatively just use the IDE's Memory View - which will work with any supported debug probe - including the LPC-Link2 with the default NXP CMSIS-DAP firmware.  More details in this previous post : https://community.nxp.com/message/997053?commentID=997053#comment-996621
Hope this helps!
hemanthvasista
Hello Andy,
Thanks for your valuable inputs, its easier as my development IDE is MCUxpresso.
regards,
Hemanth
jingpan
Hi Hemanth,
Jing
hemanthvasista
Hello Jing,
Thanks!! I was looking for a similar tool.
Do I need a J-Link license to use this?
I tried enumerate the LPC LINK-2 as J-Link, but it is unable to connect by USB.
I referred to below link:
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/lpc-link-2/
Could you help me enumerate LINK-2 as J-Link?
Thanks!!
regards,
Hemanth
jingpan
Please use this tool.
LPCScrypt v2.1.1 | NXP
Jing
hemanthvasista
Hello Jing,
Thanks for your inputs. It worked for me now.
The problem, I forgot to put back the JP1 in LPC LINK-2.
Thanks for your inputs!!
regards,
Hemanth
