1. MULTI IDE 7.1.6 is Installed.My Board is NXP S32K144EVB-Q100.
2. 30-day Green Hills Compiler license for MULTI ARM v7.1.6 is successful.
3. RTM 3.0.0.exe is installed, the installed path is C:\NXP\S32_SDK_RTM_3.0.0.
4.I created a new project, I refer to the 《S32SDK_for_S32K1xx_RTM_3.0.0_ReleaseNotes.pdf》,GHS Compiler and Linker and Assembler Options are already set
5.How to import a Reference Program of S32_SDK_RTM_3.0.0 into MULTI IDE 7.1.6 ?
The path of a Reference Program of S32_SDK_RTM_3.0.0 such as:
C:\NXP\S32_SDK_RTM_3.0.0\examples\S32K144\driver_examples\communication\uart_pal_echo
I can not find the Cpu.h file in the C:\NXP\S32_SDK_RTM_3.0.0\,Can you help me?
The compilation information is in attachment.
