hi,
i am using FRDM-ke02z board. i did try to update OpenSDA bootloader in that board. i was following steps in this link Illustrated Step-by-Step Instructions: Updating the Freescale Freedom Board Firmware | MCU on Eclips.... now my board opensda led 2 seconds off followed by 8 rapid on/off blinks (error mode).how to comeout that error mode or how to update my bootloader?
please help me
thanks
Which PC windows system you are using?
If you are up the win8 system, the P&E micro side already mention it in the FAQ:
https://www.pemicro.com/opensda/faqs/faqs.cfm
Important: If you are currently running Bootloader version 1.10 or earlier, you will need to find a Windows XP or Windows 7 PC to perform this update.
Please follow these steps to find out what version of Bootloader your board is programmed with:You need to find the win7 system to upgrade the bootloader.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
