I want a CPU with bigger float point processing capacity such as 13GFLOPS .Is LS1043A@1.6GHz OK for me? How much GFLOPS is LS1043A?
Possible references:
Floating-Point Operations Per Second (FLOPS) - WikiChip
Please pose the question to the ARM support directly if you will need additional information:
