Hi , comminity:
I have downloaded L4.19.35bsp, now I just want to download the source package first.
But when executing the command
bitbake imx-image-full -c fetchall
It will prompt without this command.
ERROR: Task do_fetchall does not exist for target imx-image-full (/home/duxy/L4.19.35/sources/meta-fsl-bsp-release/imx/meta-sdk/recipes-fsl/images/imx-image-full.bb:do_fetchall). Close matches:
do_fetch
ERROR: Command execution failed: 1
how to do it ?
Solved! Go to Solution.
Hello Coin Du,
There was a change on the latest Poky releases where the way the commands are handled.
$ bitbake <IMAGE_OR_RECIPE> –c fetchall
Was deprecated in favor of:
$ bitbake <IMAGE_OR_RECIPE> --runall=fetch
So please try using this command instead.
Hello Coin Du,
