With S32 Design Studio and MPC5748G I am starting with the FreeRTOS project and I am trying to add a UART console.
I am having problems.
Do I need to have the rxCALLBACK for the UART interrupt be inside a task?
Do I need to initialize the UART inside a task?
What are some "rules" of using FREERTOS I might be missing? I seem to get a character output but the program gets lost in the weeds with an OSIF_SemaWait() routine
Solved! Go to Solution.
Thanks Hung.. this is great!! I am attaching a fill project here
Hello Daniel Wax,
I would like to answer your question:
[Hung] From my understand, no we do not to have the rxCallBack
[Hung] From my understand, no.
[Hung] I guess that you have called the function LINFLEXD_UART_DRV_SendDataBlocking outside a task and then the program gets lost. From what I know, the LINFLEXD_UART_DRV_SendDataBlocking should be called in a task. I have modified the main of freertos example(examples\MPC5748G\demo_apps\freertos\Sources\main.c) to send a log in task, please find it in attached file.
