iMXRT reboot
iMXRT reboot
mspenard603
How does one reboot, in software, an iMXRT1062?
jeremyzhou
Hi Mike,
Thanks for your reply.
it can make the RT1062 reboot via calling NVIC_SystemReset();
I've attached a sample code that inherits from the hello_world demo in the SDK library. And the testing result is also presented below.
 * Copyright (c) 2013 - 2015, Freescale Semiconductor, Inc.
 * Copyright 2016-2017 NXP
 * All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
#include "fsl_device_registers.h"
#include "fsl_debug_console.h"
#include "board.h"
#include "pin_mux.h"
#include "clock_config.h"
 * Definitions
 * Prototypes
 * Code
 * @brief Main function
int main(void)
    char ch;
    /* Init board hardware. */
    BOARD_ConfigMPU();
    BOARD_InitPins();
    BOARD_BootClockRUN();
    BOARD_InitDebugConsole();
    PRINTF("\r\n hello world.\r\n");
    while (1)
        ch = GETCHAR();
        if(ch == 'y')
          NVIC_SystemReset();
        PUTCHAR(ch);
TIC
jeremyzhou
Hi Mike Spenard,
Actually, I'm not very clear about your question, please you can clarify it.
TIC
mspenard603
Sure, I'm simply looking for a way to make a call that reboots the MCU.
jeremyzhou
Hi Mike,
#include "board.h"
 * Definitions
 * Prototypes
 * Code
int main(void)
    char ch;
    BOARD_ConfigMPU();
    BOARD_InitPins();
    while (1)
        ch = GETCHAR();
        if(ch == 'y')
          NVIC_SystemReset();
        PUTCHAR(ch);
TIC
