What to do once no interrupt to handle for XGATE?
1,287 次查看
HUST
Hi ,I wonder what to do while no interrupt to deal with for xgate module? Idle or sleep or active for NOP? thanks
标签 (1)
标记 (1)
2 回复数
345 次查看
HUST
9s12XE,   will  the xgate  keep running   afer enable, which means consume the power?  or, the xgate will automatically enter the sleep(standby) mode after the interrupt finished to save the power?
345 次查看
admin
Specialist II
Greetings, are not clear a question not much.... In general Xgate it is developed for fast interrupt processing. You use what processor? Esteem in datashete there all should be written...
