What debug adapters support the MAC57D5xx?
matsuda
Hello!
I would like to debug my MAC57D5xx microcontroller using the S32 Design Studio for Arm.
The debug adapters supported by S32 Design Studio for Arm are listed on the S32 Design Studio for Arm website as SEGGER J-Link (w/SEGGER GDB Server), P & E Multilink/Cyclone/OpenSDA (with P & E GDB Server), but the MAC 57 D5xx is not listed on the support list of the debug adapter manufacturer's website.
Can anyone tell me which debug adapters are available?
jiri_kral
I tested debugging only with PE Micro Multiling FX and Lauterbach. Both probes are working okay. I'm not sure about Segger J-Link. I'll try it tomorrow and let you know.
Jiri
matsuda
Thank you for answering my question.
Also, thank you for contacting us about a debug adapter that has been tested.
I am looking forward to the result of the Segger J-Link operation check.
jiri_kral
Segger J-Link doesn't support MAC57D5xx. In my opinion - PE Micro Multilink FX is good choice.
Jiri
matsuda
Thank you for an answer!
I will buy PE Micro Multilink FX that you recommended.
You’ve really helped me out here. Thanks so much!
