The LS1046ARDB is connected to PC via IP router and it is work
LS1046ARDB <--> IP Router <--> PC
I try to connect both directly but I can get the ping value.
LS1046ARDB <---> PC
LS1046ARDB:
vim /etc/network/interface
iface fm1-mac9 inet static
address 192.168.0.140
netmask 255.255.255.0
gateway 192.168.0.1
network 192.168.0.0
PC (Ubuntu 18.04):
address 192.168.0.110
gateway 192.168.0.1
network 192.168.0.0
The Network Cable:
CAT5E Network wire and Cat5E Network wire with cross.
Should I modify kernel or I miss something ?
[Solved]
