I am working on FRDM-KW36 on mcuxpresso ide. I was looking for sample codes for CAN protocol through which i can read the data of any car(PID value).There are some flexcan sample example available on the ide but i am facing a lot of problems for communication between the devices.
Please help me in the implementation of code or any sample code regarding this topic will be appreciable.
Thanks in advance.
if you are just using the FlexCan demo you will need to guarantee the baudrate and the quantums to match your device.
[KW36] FlexCAN Bit Timing Parameters Setup
Please check the community thread above.
Also, you can try the following set up for your tests and verify if this works on your side
Estephania
