MC56F84763VLH with PCmaster
jixiangli
hello,
    Our company is currently using mc56f84763vlh to make products.The compilation environment used is CODE WARRIOR V10.6. The downloader used is  USB Multilink Universal, And it has been able to download the program successfully.
    But our engineers want to connect PCmaster to observe internal variables.I don't know how to operate the link, I hope you can provide help and see how to connect successfully,It's better to give specific operation steps. Thank you very much.!
     thank you!
xiangjun_rong
Hi, JiXiang,
I have checked the option of device, I do not think there is "Muitilink Universal device" option, so I think you can not use the Muitilink Universal device to transfer data between PC and target board.
Can you use the RS232 or virtual COM port to transfer data?
Xiangjun Rong
xiangjun_rong
Hi, JiXiang,
Xiangjun Rong
jixiangli
Hi, xiangjun.rong,
First of all, thank you very much for your warm answer. The engineer has solved the problem. Thank you very much!
