Hi NXP Team:
I had a problem debugging freertos;
I use your demo project " freertos_mpc5744p",and debug it;Your IDE (S32 DS) console window print the following error :
"Error in ONCE status register during instruction execution. "
then I found out,the error is caused by the function :
g_clockState.callbackConfig[callbackIdx];
I don't know if I need to configure anything, (eg:using clockMan, etc.)
Can any one help me to solve this problem, thank you.
Best wishes!
the only advice here is to check the clock settings. Do you have the same crystal frequency as configured in the project?
Lukas
