About LCD1_DATA pin for BOOT_CFG setting
goto11
hello,Community
Pins not used for the purpose of the Boot function
Can I connect directly to GND without a pull-down resistor?
best regards
Goto
gusarambula
Hello Goto,
It’s recommended that you connect to ground using a resistor to limit current drain.
I hope this helps!
gusarambula
Hello Goto,
I hope this helps!
