Calibration and measuring for S32V234
283230333
The chip used by our controller is S32V234, which uses the Linux operating system. We want to calibrate and modify the parameters of the application running in the hardware. We also want to be able to monitor and measure some of the variables in the application. So we would like to ask, is there a way similar to CCP or XCP to calibrate and measure the data in the application? Or is there any other way to calibrate and measure the data in the application?
