Hi,everyone!
I found a problem when I referred to the example code. the codes "while(RTC->MOD)" will spend more than 1 second.I use the oscilloscope to observe in my project .Could you help me?
mcu:keazn8
example code:
void RTC_DeInit(void)
Disable_Interrupt(RTC_IRQn);
RTC->MOD = 0;
while(RTC->MOD);
if(RTC_GetFlag())
RTC_ClrFlags();
RTC->SC = 0;
while(RTC->SC);
SIM->SCGS &= ~SIM_SCGC_RTC_MASK;
My code:
RTC_MOD = 0;
while(RTC_MOD);
if(RTC_SC_RTIF_MASK == (RTC_SC & RTC_SC_RTIF_MASK))
RTC_SC |= RTC_SC_RTIF_MASK;
RTC_SC = 0;
while(RTC_SC);
SIM_SCGC &= ~SIM_SCGC_RTC_MASK;
Solved! Go to Solution.
A write to the RTC modulo register is latched until the RTC counter overflows
To avoid the code blocking you can use the RTC interrupt to inform you when it has completed this "parking" of the timer so that it is in its reset state again.
You might like to also try changing the clock source in RTC_SC after setting the module to 0 since it states that doing this will clear both the module and counter, which may then be instantaneous.
Mark
Complete Kinetis solutions for professional needs, training and support: http://www.utasker.com/kinetis.html
Kinetis KEA128:
- http://www.utasker.com/kinetis/TRK-KEA128.html
- http://www.utasker.com/kinetis/FRDM-KEAZ128Q80.html
uTasker: supporting >1'000 registered Kinetis users get products faster and cheaper to market
Request Free emergency remote desk-top consulting at http://www.utasker.com/services.html
Open Source version at https://github.com/uTasker/uTasker-Kinetis
Mark
Kinetis KEA128:
