Hello
How to config the CONFIG_USB to disable and avoid .config replace by <buildroot>$make?
Thanks for help.
Paul
Solved! Go to Solution.
You could modify u-boot source code in "build_dir/target-aarch64_generic_musl/uboot-layerscape-ls1043ardb/uboot-layerscape-lsdk-1903/" directly,
eg.
build_dir/target-aarch64_generic_musl/uboot-layerscape-ls1046ardb/uboot-layerscape-lsdk-1903/configs/ls1012afrwy_tfa_defconfig
eg.
Hello Paul Young ,
You could clone u-boot source code, perform your modification and generate a patch to put it in folder package/boot/uboot-layerscape/patches/.
Please get u-boot source address in package/boot/uboot-layerscape/Makefile.
PKG_SOURCE_URL:=https://source.codeaurora.org/external/qoriq/qoriq-components/u-boot
PKG_SOURCE_VERSION:=80b2d2bc4cab0a8363c9b7eba8064b1795f12670
git clone qoriq-components/u-boot - U-boot Tree for QorIQ support
git reset --hard 80b2d2bc4cab0a8363c9b7eba8064b1795f12670
In u-boot source code, please modify configs/ls1012afrwy_tfa_defconfig and generate a patch, then put it in folder package/boot/uboot-layerscape/patches/.
Yiping
