Hi All,
I tested different USB drives with the usb_host_msd_fatfs example. Unfortunately for Kingston DataTraveler 100 G3 64 GB doesn't work at all. The device won't be successfully enumerated.
Through debugging I found out that it stuck at kStatus_DEV_GetDes8 state and the _USB_HostKhciProcessTrCallback() function will be always called with err==USB_KHCI_ATOM_TR_BUS_TIMEOUT.
Any idea ? Did anyone experience the same problem?
Thanks !
If you have a FRDM-K64F board could you see whether it works with this solution?
http://www.utasker.com/kinetis/FRDM-K64F.html#MSD-HOST
It has a binary file that can be loaded to the board.
Mark
Complete Kinetis solutions for professional needs, training and support: http://www.utasker.com/kinetis.html
Kinetis K64:
- http://www.utasker.com/kinetis/FRDM-K64F.html
- http://www.utasker.com/kinetis/TWR-K64F120M.html
- http://www.utasker.com/kinetis/TEENSY_3.5.html
- http://www.utasker.com/kinetis/Hexiwear-K64F.html
uTasker: supporting >1'000 registered Kinetis users get products faster and cheaper to market
Request Free emergency remote desk-top consulting at http://www.utasker.com/services.html
Open Source version at https://github.com/uTasker/uTasker-Kinetis
