Is it possible to store network data (PANID, channel, node information for coordinator, short address, PANID, channel for end devices) and allow the devices to resume communication after a network reset?
Sorry, maybe I wasn't clear with my question. The problem is not storing the data between resets, but how to use the stored data to resume connection from the end device to the coordinator, without scanning for available networks again and going through the association process.
Which protocol are you using ? Is it ZigBee? Thread? 802.15.4?
Estephania
