i.MX8MQ USB PHY "USB3_GLUE" registers
christian_mauderer
We have some trouble with USB Super Speed signal quality on a i.MX8MQ based custom board. I noted that in the Reference Manual Rev 1 (see [1]) there is a chapter "11.1.3.2 USB3_GLUE register description" with a lot of registers that most likely have an influence on the signal (like pcs_tx_deemph_6db or tx_vboost_lvl). Most of the registers are only described as "USB3.0 PHY Signal". Is there some more detailed description available somewhere? It seems that these are not standard names. At least I didn't find anything in the USB standard or the web with these names.
Thanks in advance for any hints.
With kind regards
Christian Mauderer
[1] i.MX 8M Applications Processor | Arm® Cortex®-A53, Cortex-M4 | 4K display resolution | NXP
AldoG
Unfortunately the only available information we have is the one in our documentation, Reference manual and Datasheet.
Sorry for the inconvenience,
Aldo.
christian_mauderer
Hello Aldo,
thanks for the response although it's not what I wanted to hear.
Do you know of some unofficial documentation for these registers like (for example) some comments in some driver or similar? For most registers the name already suggest a meaning. But I'm not really sure about allowed values.
With kind regards
Christian Mauderer
AldoG
I apologize but we don't have any other type of documentation available, detailed documentation can only be provided by the owner of the IP, Synopsys.
Sorry for the trouble,
Aldo.
christian_mauderer
Hello Aldo,
thanks for the information. I had the impression that also the USB 3 controller is from Synopsis (dwc3) the PHY is vendor specific. Some of your competitors that are using the dwc3 too have a completely different set of PHY registers.
If it is a Synopsis IP: Is there some name or description for the Synopsis PHY IP that I can use to find more information on the Synopsis site or on third party sites?
Christian
