Dear All,
I am trying to use 8 CAN on MCP5748G. Now any three CAN work well. It doesn't work if add more CAN.
I´m using S32DS for Power Architecture 2017.R1 build 171018.
Thanks!
could you please specify in more detail what is not working?
Do you use SDK based code or non-SDK? For first one, what version do you use?
What is your HW and bus topology? Can you explain connection between CAN module, transceiver and CAN bus?
BR, Petr
