Hi, Can you give info on GPIOs and Interrupt pins details.
In my design, I am using GPIO2_IO11 pin A15 as an interrupt in i.mx6ull.
So can I use that GPIO pin as an interrupt pin?
Solved! Go to Solution.
Hi prabhu
any gpio can be used as interrupt source, some examples can be found on
Configured GPIO interrupt but ISR is not hitting
Hi prabhu
Hi Igorpadykov,
Thanks for your help.
