About S32K144 Flash Write Read Erase
alexwu
Dear,
Can you supply code sample about "FLASH write / erase / read" based on S32K144 core chipset.
Thanks.
Alex
jorge_a_vazquez
Hi Alex Wu
The Flash_partitioning example project that comes with the S32DS (using the SDK) makes those operations as a part of the example code, you can check it and please tell us if you have any question about it.
TIC
- If this post answers your question, please click the "Mark Correct" button. Thank you
alexwu
Dear TIC,
What I want to do is to open EEE area to use it as power loss data storage.
But as I understood, If partition the FLASH, all my data includes code data will be lost, Right?
I hope you have EEE code sample for reference.
Thanks.
Alex
