ths for reply.
The schematic shows 16 bits RGB format,but I want 24 bits parellel RGB 888 input. Is there a method which supports this format video input?
Could the methods meet requirement as following picture? If so,which one is best?
pls refer to the Table 64. Camera Input Signal Cross Re
ference, Format, and Bits Per Cycle of data sheet:
ths,xie.
by the way,does this chip support LVDS input similarly to TI DS90UB928 Deserilalizer's output signal?
depends on what output format from Deserilalizer, you can check if imx6S Reference Manual supports this format or not.
for connecting, you can refer to the imx6q AI board
SABRE-2|Automotive-Infotainment|i.MX6 | NXP
find the schematic,
