I am using the S32K144EVB-Q100 evaluation board to develop customized CAN BUS bridges & gateways for a client.
We need to test a few protoypes on the field before starting to design the product (with its own custom made PCB).
Are there OEM manufacturers of S32K144 boards that could sell us boards with a commercial licence instead of EVALUATION ONLY.
Ivan
Hi Ivan,
NXP provides only EVB boards which are not supposed to be used in end product. The EVB boards are for prototyping and evaluation only.The reason is that the boards are designed to provide high configurability and universality, so it does not follow all standard design rules and it may not be reliable at corner cases.
Unfortunately I'm not aware of manufacturers providing such boards.
Lukas
