I can't debug a M4 application that should run on DDR. I'm using eclipse and J-Link. If I use TCM or OCRAM everything works as expected. I need DDR because the size of the application will exceed 300KB of code.
Could anybody help me?
Marcelo
Hi Marcelo
one can try to reuse scripts provided in ddr test
https://community.nxp.com/docs/DOC-105652
and integrate them if necessary to jlink scipts
