I am new to QN908x BLE development environment.
I have imported SDK Example code listed in MCUExpresso IDE.(SDK_2.x_QN908XCDK version:2.2.0)
Example code: HID Device bare metal.
I have followed the steps in readme file, but I am not able to see HID device while scanning on Mobile device.
I am able to load other example code and
Is there any document explaining how exactly this example code works or any document explaining the structure for setting up of BLE profile.
Solved! Go to Solution.
No, it is not available on the web page, once you install the SDK there will be a folder with documentation:
<installation path>\SDK_2.2.0_QN908XCDK\docs\wireless\Bluetooth
When building the package in the MCUXpresso dashboard, you can also see there a link to download the documentation separated.
Estephania
Did you check the BLE Demo Applications User's Guide? I believe chapter 5.6 HID Device (Mouse) will be helpful.
The document is available on the SDK documentation
Estephania
Hi Estephania,
https://www.nxp.com/docs/en/application-note/FRDMKW40ZDAUG.pdf
https://www.nxp.com/docs/en/user-guide/UM10995.pdf
Are you referring to any of these one.
If not, can you please point the link where the document is.
I am not able to get it from NXP Documentation link (Documentation | NXP ).
Estephania
Thanks Estephania for pointing the location for the document.
Now, I am able to get the device.
Thanks a lot.
