Can I calculate velocity from accelerometer / magneto-meter and gyroscope ?
dviver10
I want to calculate velocity and distance from IOT sensors. How can i do this?
estephania_mart
You can try to use the AN3397  as a guide for implementing position algorithms using accelerometers.
It is not the same devices that are in the rapid iot , but it can give you a hint on the implementation.
Estephania
