Hi FSL engineer,
Could you please advise me the Part Number Nomenclature of i.MX 8&8X? Thank you.
because these parts are still in preproduction, so haven't released part number nomenclature yet.
Now that the i.MX 8X production is launched, could you provide the part numbering scheme? This can normally be found in a datasheet, but strangely, it is not the case for i.MX 8X... There is only the list of available part numbers, without a description for each letter. And that's a problem since for example, in the Industrial datasheet, the following two part numbers are listed with exactly the same description so we can't know what is their difference: MIMX8QX6CVLFZAC, MIMX8QX5CVLFZAC.
Thanks.
Étienne
Any help regarding this?
Étienne
