Dears,
We found some MPC5606B chip locked which means I cannot connect via U-Multilink and update app. again, while I update app. failure. Can you help to advice?
BRs,
Ray Deng
Thanks, Lukas.
there’s only one thing which can cause such troubles - have you modified shadow flash memory during app update? Shadow flash contains censorship information. If the shadow flash is erased, it is necessary to program the censorship control words appropriately (before next reset) otherwise the chip will be locked forever. And there’s no way to recover in this case.
The only way to recover is to have some code already loaded to MCU which checks the censorship information and which restores it if necessary (that means with no JTAG debugger intervention). But such code must be loaded to flash BEFORE(!) the chip is locked.
We have two examples here on community:
https://community.nxp.com/docs/DOC-102582
https://community.nxp.com/docs/DOC-332307
It shows how to erase the shadow flash and how to program censorship information back to shadow flash. There’s also shown how to unlock the chip using a debugger and known password.
Lukas
