How to change NAND partitions in i.MX6UL EVK
keshavakumarb
I am using NAND as a boot media in i.MX6UL evk. I want to change the partitions and partition size of the NAND. When I did some exploration on this, found that partitions are defined in "include/configs/mx6ul_14x14_evk.h" file, CONFIG_MFG_NAND_PARTITION .
If I want to change the partitions, whether changing CONFIG_MFG_NAND_PARTITION is sufficient?
Ex :
      #define CONFIG_MFG_NAND_PARTITION "mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),50m(rootfs), -(data) "
I am using MFG tool for flashing purpose. I will place generated u-boot.imx in "Firmware" folder of MFG tool.
Please confirm my understanding. :smileyhappy:
Hi Keshava
I think this is correct and should be sufficient for changing the partitions.
Hi Keshava
keshavakumarb
Thank you for confirmation. I acknowledge that it works. :smileyhappy:
