Second Ethernet(Eth1) Renaming issue
yashavanthashet
Contributor V
We are using i.MX8M custom board with "fsl-yocto-L4.9.51_mx8mq-ga" release.
In our board we are using 2 Ethernet phys. First Ethernet eth0 from Atheros and second Ethernet from Realtek.
Here the issue is while booting second ethernet is getting renamed to 'enp1s0' from 'eth1'. Please see the below print from the boot print.
"r8169 0000:01:00.0 enp1s0: renamed from eth1"
Kindly let me know how to remove this renaming, I don't want renaming instead wants second ethernet to be eth1 only.
Thanks in advance,
Yashavantha
b36401
Please check udev rules. Possibly ethernet interfaces are renamed there.
Victor
