I am very new to the NXP s32k148 evaluation board. I have been trying to reset the board to the example application (RGB LED blinking). I have attempted to press the reset button (SW5) to reset the board. This is not working. Any help would be appreciated. If jumpers need to be changed, please include that in your answer.
Solved! Go to Solution.
Have you reprogrammed the MCU? If so, you erased the pre-loaded RGB firmware (S32K148 EVB JumpStart).
You can download the project from the S32K148EVB product web page and load the MCU again in S32 Design Studio.
Hi I have same issue, and when i try from SDK studio i get below error
