Hello ,
I configured LPSPI Driver to transmit some dummy 16bit data on MOSI and its working(measured on CRO).
I have one doubt with respect to MISO capture?Is LPSPI will support Full duplex communication means in one instance i can put the data on MOSI and as well as i can read data on MISO?
or in First instance(16 clocks) i need to send data and in next instance(16clocks), i must read data on MISO?
Actually, I want to establish LPSPI 16bit communication with SBC(FS45xx).
Thank you.
Yes, the LPSPI support full-duplex mode, simultaneous transfers in both directions.
