CW 7.1 Debug problem
eric_prince
Hi team!
I'm using CodeWarrior 7.1 with a full licence.
My code compiles, but when I'm trying to open the Flash Programmer (by hitting Debug), IDEAuxiliaryResources.dll (v5.9.0, build 3024) pops a message saying: "Can't find executable file %s. It may need to be rebuilt.". Can you tell me under which circumstances (why!?) does this message come up?
Thanks!
Carlos_Mendoza
Hi Eric,
Could you tell us which MCU  and operating system are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
eric_prince
After verification the target MCU is: MCF5234CVM150 (FREESCALE SEMICONDUCTOR : IC MCU 32-BIT COLDFIRE MCF5234 V2CORE 64KSRAM MAPBGA-256)
The operating system is Vista 32 bits.
Thanks for your patience. Can you look at the source code for that library?
Carlos_Mendoza
Hi Eric,
This CodeWarrior version has limited Windows Vista support, the latest classic version 7.2 does support Windows Vista 32-bit:
CodeWarrior® Development Tools for ColdFire®|NXP
You will need to follow the TN268 in order to migrate to CodeWarrior 7..2:
https://www.nxp.com/docs/en/application-note/TN268.pdf
Carlos Mendoza
