S32K144 on debug/off debug
maojun
MCU TYPE :  S32K144
Hi,could anyone tell me what the difference between debug mode and off debug mode?
some problems could happened off debug mode ,but it could not recurrent when I was debug.
thanks a lot.
danielmartynek
What do you mean by "off debug mode"?
maojun
Hi Daniel:
   "off debug mode" means that "burn the chip,and let it run without using emulator debugging "
danielmartynek
Do you use S32 Design Studio?
If so, some information can be found in this thread: Debug options to select in S32 Design Studio
Please refer to S32DS documentation in the installation folder
...\S32DS_ARM_v2018.R1\S32DS\help\
maojun
ok ,thanks
