32kHz clock for MMPF0100ANES
teikhooiteoh
Anyone has the 32kHz internal clock accuracy / tolerance for the MMPF0100ANES PMIC?
I need it to estimate the tolerance of start up sequence for the regulator outputs.
Please help. Thanks!
Labels (2)
guoweisun
Hi Teik
Unfrotunately we don't have 32KHz accuracy / tolerance for customers reference,so you can see the start up timing only have the typical value in datasheet.
You can only to test start up operation for the worse case analysis.
