library files
library files
519683945
How S32 DS updates library files and restores library files?(I found that when I modified the library file, I couldn't recover. By the way, where is the withdrawal key for 32DS?)
much thanks!!!
Tags (3)
jiri_kral
what is your S32DS version (ARM, Power PC, Vision)? What you mean by library files? Your library files you need to maintain by yourself. Standard C libraries (EWL, NewLIB) aren't under user's control. Please share more details about your issue. Thank you.
Jiri
519683945
My S32DS version is ARM.I am Writing a program to S32K 148.but the Official driver is changed by myself,I want to know how to get it back.by the way,S32DS for ARM Is there a recall function, and if so, where is it?thank you very much!
jiri_kral
If you modified part of SDK, I'm affraid that only re-install can bring back original setup. There is no rollback action.
Other possibility may be uninstall that particular SDK and run update again - but I didn't try it:
Jiri
