I have brought a FRDM-KW41Z, but now the multi-colored LEDs(RGB) is not flashing, that is to say , the board I can only see the two green LEDs are bright. I unplug and replug in the board, but the multi-colored LEDs(RGB) is still not flashing. How can I do, so that the multi-colored LEDs(RGB) can flash?
Hi Xiaoxuan Cai,
Seems that you are following the GETTING STARTED of FRDM-KW41Z board.
Not quite sure why the Out-of-Box Demo is not running on your FRDM-KW41Z board.(Maybe some one else has erase the program?)
I think you can go on with Next Step. This step is not much important, and it will not effect next steps.
Robin
