Hello everybody,
I have currently a project running with gcc and KSDK 1.3 who compile and runs perferctly. I don't use any IDE to work and compile that project.
I want to update the KSDK version to the latest one (2.4) but i can't have something running even with trying to adapt the Makefile. If i remember well, i used KDS to compile the platform library in the KSDK 1.3, then i just added it in my project git repository and in the Makefile.
For the new version i don't know how to proceed. Is there any documentation which explain how to do because i am really lost?
Thank you in advance,
Thomas
Solved! Go to Solution.
Hello Thomas,
When you build your SDK with MCUXpresso SDK builder you have the option to select your Toolchain/IDE. You can select GCC ARM Embedded or MCUXpresso IDE. MCUXpresso IDE is our newest IDE and it's the replacement of KDS.
I highly recommend you to use MCUXpresso IDE. In the User guide you will find all the information you need on how to work with the SDK.
Hope it helps!
Victor.
Hello Thomas,
Hope it helps!
Victor.
