HI All.
I User the Application Note"JN-AN-1172 JN516x Customer Module Evaluation Tool"for Tx Power Test,max Tx Power about 10dBm,but i can't control the Tx Power adjust to 8dBm.
Maybe it doesn't do much in the use,but it important for FCC certification.
As you know, the JN-AN-1172 has by default only 5 TX power. You can modify that value, also taking as reference the
IEEE 802.15.4 Stack User Guide v2.6 3.8.1 Transmission Power
CustomerModuleEvalTool.c
Hope it helps and please let me know your findings.
Mario
