can not login the system of OM5577-PN7120S_BBB_Linux_demo_v1.1
nicholas_duan
When I use the document of AN11646 which i want to test the OM5577/PN7120S kit,  after i write the image of OM5577-PN7120S_BBB_Linux_demo_v1.1 into the BeagleBone Black , and then  i want to connect the board via SSH over USB with PuTTY. I enter 192.168.7.2 as the host address,and the PuTTY show me the prompt "login as :"     and i type root and press enter  . But it shows me  Access denied and i can not login the system. Can you tell what can i do to login the system
weidong_sun
   The password should be for linux OS on raspberry board.
    you can try the user and password:
user: pi
password: raspberry
 If not logging in normally, you can check user' guide of "raspberry pi" or ask provider for help!
Have a nice day!
weidong sun
