The chip is always on reset after power on
578294688
Hello,my board is S32R274 evb,today I meet a situation that the yellow LED is always light on after power on,in other words,this is the chip is on the state of reset.The reset pin is always low.It is appeared when I download the program using OSJTAG?
What happen about it?Is the chip locked?If like that,can i unlock it?
Thank you!
martin_kovar
we are dealing with this issue via internal case. If we find any solution, we can post it here into this thread.
Martin
578294688
Hello,Martin,thanks for your reply.ou
please keep us updated. It is urgent case. please escalate to your team.
Thanks in advance.
dongdong dong.
578294688
And I test the reset pin,there is three stage like the picture,power-off to power-on,and then power-on to power-off.
